Merc 90 4 stroke 2000
Jacques321
My Merc 90 4 stroke tends to stall if I push the throttle down hard even after a ten minute warm-up!! Later after I run it for a while it seems to be OK.<br /><br />Now my marine mechanic checked it out, and here's what he did:<br />- calibrated the carbs<br />- changed a fuel pump (my engine's only 1 yr old!)<br />- One of my choke sensors was cracked, but not faulty!!(CAN YOU BELIEVE THIS!)So they changed that($320 part on warranty)<br /><br />I got my boat back and the shop told me everything was ok.<br /><br />So I launch the boat and warm up the 4 stroke for 10 mins. My RPM's drop to 800. So I try it again I open the throttle(swiftly), wide open, and you guessed it the engine stutters and dies. I tried this 3 times and got the same result. If I bring the throttle down a little slower it's OK. GO figure?<br /><br />I called the shop and they told me that a carbureted 4 stroke will not respond as quickly as a 2 stroke fuel injected, especially with a heavier SS prop. I told them I already knew that and that it doesn't seem normal that my engine should stall on me even when it's still a little cold.<br /><br />Anyone else wth a 4 stroke having this problem?<br /><br />------------------<br />Princecraft 164(2000)<br />Merc 90-4 stroke<br />Prop:Vengeance SS 16P
JB
Re: Merc 90 4 stroke 2000
Your wrench is almost correct, Jacques. What he didn't tell you is that Yamaha didn't put accellerator pumps in the carbs. No carbureted 4 stroke outboard that I know of has acc. pumps. When you open those big throats all at once the rush of air leans her out and she dies. A little practice will get you to the point that you can open her up more smoothly and all will be well.<br /><br />You don't have a problem. You have an engine that responds differently than you are used to. EFI 4 strokes don't do that, if you are wondering.<br /><br />Red sky at night. . . .<br />JB
ODDD1
Its like goin to the doctor an sayin 'it hurts when i do this'....DONT DO THAT....
hondon
Don't mean to step on your toes J.B. but yes they do have acc. pumps . They have a diaphram that pumps air into the nozzle well forcing fuel into the throttle body. Problem is mercs won't work until the enrichment process is complete. Some times 10 minutues or more.
hondon
By the way ,while I'm right here.Did the dealer that sold you this include a water separating fuel filter.If not add one tommorow.I've been in these carbs and it is INSANE.J.B.is right about the different characteristics of these motors.
JB
Thanks, Hondon. I learned something tonight.
