I was in the neighborhood of the water pump on my 9.9 merc and noticed the shaft seals between the gear lube side and the water side looked shabby. I bought new seals but I am worried that the running surface on the shaft may be damaged. There is a slight ammount of wear and pitting. Very slight I might add. Is this a problem? Also, Should I go ahead and replace the prop shaft seal too? Looks like I need a special tool to do it.
