Re: merc 9.8 pull cord
Hi Rocks,<br /> You don't list a model number. Depending on the year, there could be a neutral lock-out feature that prevents the motor from being started in gear. It involves a lever that is actuated by the shifter and locks the recoil from turning. Should be visible if you remove the cowling.<br /> If it lacks that, you should be able to turn the flwheel by hand. No turn, then something is locked up. Could be the powerhead or lower unit... Let us know what you find...<br />- Scott
