LV2BT
- Jan 8, 2010
- 11
Hi all,
Need help with a 1963 Merc 850 (85hp). This is an inline 6cyl with 2 fuel pumps and 3 carbs if its helps. Bought her used and it has been sitting for a few years so I was quite surprised when I filled her up with fresh fuel and she fired right up. Runs great with or without load for 10 - 15 minutes and then seems to starv for fuel as pumping the primer bulb continuously gets it going again. Rulled out the tank and line by using known good ones. Bought a pump rebuild kit and redid the top pump (stupid me thought there were 2 diagrphrams per kit) and no change. Haven't gotten to the bottom pump yet. Thought I would ask if this is a known issue before picking up more parts (2nd fuel pump kit and parts needed to do the fuel vacuum/pressure testing). Should mention that the diagrphams in both pumps "looked" fine (no visible pinholes or obvious tears) as did the check vavles. Not really keen on rebuilding the carbs since it seems to run 100% when cold or sitting for 20 -30minutes. Plenty of power, no issues at WOT until she warms up. Once dead, its prime, prime, prime, prime, prime, prime some more, prime, choke crank crank crank vrooom..... runs ok for 1-2 minutes then runs out of fuel (or so it seems)
Any ideas?
Oh.. motor also has a bad rectifier. not sure its relevant but though someone could confirm.
Any ideas?
