Troy_from _Oz
- Sep 29, 2002
- 126
hey all, Just after a bit of advice if anyone can help. <br />I have a merc 650 and the steering has gone tight. I have disconnected the steering cable and it is the vertical pivot tube at the motor sideof things that is stiff. I have re-greased it, pumping lots of marine grease through nipple until fresh grease comes out at bottom seal, I have also put a jack just under skeg and put upward pressure on motor to try and disperse more grease into tube, but still tight. regreasing has helped, but problem still remains. Is there anything I can do short of stripping the whole thing down, which I presume pretty much means removal of ob?<br /><br />Any way of getting degreaser into the shaft to disperse old grease?<br /><br />cheers<br />T
