billybandman
- Mar 24, 2003
- 13
I have a '69, 65 hp runs great, starts easy, and trolls all day long. I have noticed a nice oil slick behind the boat though. Recently I lowered the engine from being in the the "up" postition for 3 weeks while at home and a lot of, looks like gear oil, drained from the exhaust chamber around the prop. Made a small puddle on the driveway about 3-4 inchesin diameter. No lube seems to be coming from the prop shaft. I was quoted $250.00 just to pull the lower unit. I am very mechanical but have never worked on outboards. Is this most likely a seal/seals that can be easily replaced with normal tools or do I need lots or special , etc ? <br />Also would it hurt to use this like this as long as aI keep the lube topped off.
