Re: Merc 50hp Lower unit shift problem
The fella I bought it from replaced the water pump himself, thats when the fun began. He said it didn't bother him with the controls set up backwards. Personaly I thought it could be dangerous, so thought it best to take the bull by the horns and be done with it. Well, enough ramblin, We just came back from the lake, I had to take it on a shake down cruise. The first time we had it in the water! The shifting problem is resolved, thanks for all the help! It took me two tries to get it right. The first time all I had was forward. The 2nd try I ended up moving the plastic cam over a couple of notches on the spline shaft, and rotating the shaft ccw on the lower unit until resistance was felt. then with the shift lever in forward it slid together fairly smooth. I manualy turned the flywheel a few times while lifting on the LU before it was up tight. The cam needs to be in the postion that when you lift it up to the motor, the locking pin is on the low side of the cam. Then when you shift to neutral it rides up the cam locking the motor solid and shifting to reverse just moves the cam over a little more still keeping the motor locked and staying on the high side of the cam. I thought I would get this written while its still fresh in my mind. I hope I got it right, It worked for me, and just maybe it could help someone else thats stuck. Thanks so much again for your thoughts, it helped alot. And being a Newbe I hope I didn't rock the boat.
