Ruggybuggy
- Sep 18, 2009
- 114
Ok, I have a '98 Princecraft 14.5" boat with a beam of 73" and transom measures 70.5". Picture is an example.
The transom measure 20". The boat weight from the manufactures website is 520lbs. The boat has a full floor with livewell in front and Minkota trolling motor with battery mounted on the front with battery so the weight is probably close to 620lbs without motor. The capacity label states 35hp. The manufacturer states 35hp tiller and 40hp console steer. If I use the formula from the US Coastguards boatbuilders handbook ((0.8 X Factor)-25) I get a max horsepower of 47hp. The boat is currently running a 1998 25hp Evinrude 3 cylinder with aftermarket power tilt/trim and weight is about 168lbs. The motor I'm considering is a 2004 Merc 50hp 4 stroke and weights 248lbs. The only reason I'm considering this is because of a smoking deal of $1500 for the Merc in good condition. I know the horsepower is more then the label but I run the boat without insurance (don't need it in my location). I'm wondering about approx speed, handling issures, should I get trim tabs or hydrofoil, suggestion on prop pitch that sort of stuff.
