hotrod53
- Oct 16, 2009
- 508
My '77 Merc 500 4 cylinder was peeing fine when I moth balled last year. Yesterday I hooked up the muffs and fired it up ... no pee. I pulled the block plug by the spark plugs and it was dry, I also snaked the pee hole. Today I blew compressed air thru the drain plug and I could hear air in the intakes on the lower unit. I hooked up the muffs again and the water ran for probably 3 minutes when I realized that I had water coming out of the exhaust in the center of the prop. I started the motor and I got a pee stream. It was almost zero at idle, but I had a needle valve stuck (thanks ethanol), therefore it wasn't idling very fast. At a slightly higher idle, I got a decent stream. I pulled the carbs and put in the new ethanol compliant needles that I have had since last year.
To back up.... this is the start of the 3rd season since I rebuilt the pump, new impeller, seals, and a new impeller cup. I wouldn't think it would be shot yet, and it has only been on the river so it hasn't been ingesting any sand. I use the boat about 8-10 times a season and not long runs, my hours should be pretty low since rebuild. I also have very low water pressure at my house when I'm testing it, only about 38 psi, couple that with the muffs only feeding water in one side, I hope that explains it.
This motor has notoriously been slow to pee on startup, even with a brand new impeller, higher rpm it pees like I would expect. The original owner told me that he never changed the impeller and it lasted for ever.
I guess I won't know anything for sure till I put it in the river... any advice or input?
