Hello,<br /><br />First of all, YES i searched and read a lot, but just to be sure - let me post the 256th overheating Thread
<br /><br />I was out on the water and wanted to go up to WOT, when suddenly the rpm dropped pretty fast. Went down from 3500 to Zero in about 3 seconds. At the first look at the motor i could see smoke coming out everywhere (rests of oil etc. on the powerhead from winterizing). And only steam at the pee hole.<br /><br />My first panic reaction was to start again, and the motor started immediately. Turned it off again of course. Now i changed the impeller and drove the motor 4 days without the slightest problem. Idles smoothly, and has a lot of punch out of the hole. It ran now for approx. 15 hours. <br /><br />But i still worry, if the overheating situation did any internal damage to the motor. Is there an "easy way" to check for damage, or do i have to open the powerhead? Sometimes at about 4800-5200rpm, i find the engine to run a bit loud. A bit like "screaming". Hard for me to explain in english. The engine is pretty old. A mercury 500 4 Zylinder from 1976. <br /><br />Now my question is, open the powerhead and have a look, or "nevertouch a running system"??<br /><br />many thanks<br />martin
