Merc 500 lower unit
tmcalavy
Okay guys,<br />Got good feedback on the cost of having my lower unit re-sealed (water in lube/oil). Next question is, can this be done yourself? I'm pretty mechanical...any special tools required? Is this too much of a PIA? Advice appreciated.
Yepblaze
Re: Merc 500 lower unit
Yea you can do it. It calls for a special tool or two. Mostly a pin socket spanner arrangement thing. But with some heat from a propane torch (if needed) and a drift punch and hammer they come apart.<br /><br />Here's a poor man's tool.<br /><br />
<br /><br />Pick up a manual cause there are a few things such as shims and things that if they get mixed up on you, you are going to want to be able to check for correctness.
Rex
Will i glad you call around.<br />There one little thing you can try, but I<br />would have the dealer put the seal in.<br />I like I said $1.00 for lube is not to bad<br />to see if the seal will seal.<br />Just do it every time you are on the water.<br />After 2 or 3 time you will know if it starting<br />to work.<br />P.S. you could add about a tablespoon of<br />brake fluid with it to try and make the seal <br />soft.<br />Rex A. Hubble
tmcalavy
Thanks for the input, guys. I have a service manual coming, so I'll decide after looking at the diagrams and seeing how many little parts there are. I suspect the water pump/driveshaft seal, but could also be the shift shaft seal. don't suspect the prop seal. <br />Hey rex...couldn't follow what remedy you were talking about. How about a little more explanation?
tmcalavy
Yepblaze,<br />I like that homemade tool! I'm guessing that's what gets you into the stuff on the prop shaft.<br />How long is that pipe, what kind of pipe (not alum. obviously) and how far apart are the "teeth?" How did you cut the teeth? thanks.
tmcalavy
Thanks for the info and leads, guys.<br />Next question, which other lower units are interchangeable with my 50 hp? For example, will a lower unit off a Merc 65 or 80 hp, roughly same vintage/year range, bolt up to my Merc 500?
Rex
i think the highest you can go is a 65.<br />rex
