hotrod53
- Oct 16, 2009
- 508
For those of you who have not been helping me with this already... '78 Sylvan Sea Master with a '77 Merc 500 50hp 4 cylinder, just launched after 13 years and the boat was recently rebuilt.
I had a little bit of a rough idle in the driveway, but when I launched it, it cleared up after about 3 minutes. The idle is now smooth as can be, and it sounds great.
Issues....
* it seems to have a miss every now and then eventhough I have all new plugs, wires, rebuilt carbs, rebuilt fuel pumps... I have already ohmed the coils and they are all identical.
* if I nail the throttle I get a slight momentary bog
* it was tough to get it on plane with two 200+ people inside, maybe due to not being full throttle. Once it planes out the rpms come up a little and the speed comes up.
* I don't think that I'm hitting my 5200 RPMs, it seems as though my throttle cable may need to be adjusted. There seems to be a deadband in the middle of the throttle, it rpms come up right off of idle, the middle really doesn't do much, and I have to go a little more than 90 degrees to be full throttle which may not even be full throttle.
* I also have bubbles in my fuel line.. may be normal???
* this lower unit is not the original and the prop is now a 13 pitch, but I still have the 12 pitch.
I ran about 1/2 tank of fuel thru it today, minor issues but finally on my way!
Issues....
