Grant Manning
- Dec 26, 2003
- 10
Not sure of component terminology. Fuel/oil mix device (botton one) around crank has disintegrated. Could be due to worn bearing? Has made contact with crank web and blown apart. Bits found their way into cylinder bore. All main bearings and con rod bearings apprear worn. Will attempt rebuild but any help from you guys would be gratefully received.
