merc 470 conversion to alternator
thomasholm
I got the breezeworks single wire alternator installed with the wire from the alt to the starter solenoid battery side. What to do with the wire from the voltage regulator to the circuit breaker ? and shall I keep all the wires connected to the slave solenoid? thanks in advance for advice
Bt Doctur
Run the alt output lead to the 50A circuit breaker or connect to the Red/Purple wire from the regulator. or use the Orange wire from the regulator Remove the stator or remove the stator wires from the regulator and insulate them
click to enlarge
Pretty sure the alternator conversion had instructions
