merc 470 170hp
leeann4
Looking for some help
mercruiser 470
water in oil manifold and riser seem to be ok what is next to look for?
thanks
Re: merc 470 170hp
Ayuh,... The cam gear/ waterpump seal...
sdoomaha
Re: merc 470 170hp
Just got done pulling the head and replacing the head gasket on my 470 because of coolant in the oil. Slight crack in the gasket between the water jacket and #1 cylinder.
Engine running well? Any coolant smell in the exhaust? How much coolant are you losing each time out? If compression checks out...I would lean towards Bondo's thoughts.....
Good Luck.
