merc 402 no spark on #2
turtles11756
hello, i have a 1974' merc 402 manual start with 145lbs compression on both and it will only spark on one cylinder . replaced the stator with a new part (wires were gone) from CDI , had trigger repaired , new CDI switch box and it still only sparks on #1 .switched trigger wires (brown and white ) to see if the other cylinder would fire , disconnected kill switch, changed coils over , disconnected merc switch and it stays the same no fire to #2. the flywheel looks magnets look new . anyone that can think where to go next ? thanks any ideas are appreciated:confused:
turtles11756
Re: merc 402 no spark on #2
switched the leads at coil and now has spark on the #1 cylinder but no spark on #2 ?:confused:
