boatsinker
- Mar 8, 2002
- 6
i recently bought a 14 alu. boat from a "friend".The motor will not shift into reverse.I droped the lower unit and i can turn the shift spline and it easily will go into forward or reverse.i have the remote control removed from the motor and all linkage on the powerhead works freely. bolt the lower unit back up and push the shift linkage it will not engage reverse unless you hold hard pressure on the shift linkage.when i let go it pushes back to between neutral and reverse. 1980 40hp merc 2-cyl.need help wife wants to go fishing.appreciate any help!!!!the guy i bought the boat from changed impeller before i bought it and hadnt used it since.reverse worked fine the last time he used it.
