wood45s
- Apr 26, 2017
- 7
Merc 4.3 can?t align engine
1995 Starcraft Islander 221 recently purchased. The engine was rebuilt summer of 2016 with Chev s10 block and rebuilt heads by previous owner. It has not been on water since rebuild; only run with water hose on it some when engine was installed. They didn?t remove stern drive to install engine or check alignment. I immediately removed stern drive, fixed starter, etc. and test ran engine with water hose connected to thermostat housing. Seems to run ok.
I can?t get engine aligned yet. I am using alignment tool inserted thru gimbal bearing. Bottom line is can?t insert the tool into coupler with rear engine mounts torqued to specs 40 ft-lb. If I loosen the rear engine mount bolts I can insert the alignment tool fully. Then I tighten rear engine mounts again and alignment tool will not go into coupler, not even a little. I raised and lowered the adjustable front engine mounts a half turn at a time and never could get the tool inserted when the rear mounts are torqued down.
Maybe a washer or something was left out when the engine was installed. The only wood is a couple of ? plywood spacers for the engine mounts (front and rear) which are attached to the aluminum stringers/framing of the boat. The plywood spacers look original and appear to be in good shape best I can tell.
Maybe I should lift the rear of engine and put in a washer for spacer and try that?
Any ideas?
I will replace the gimbal bearing, but was trying to get initial alignment done with the old bearing.
Thx,
wood
Any ideas?
Thx,
wood
