I just did an oil/filter change on my 06 Merc 4.3L V6 262CID, and was given a longer filter (Quicksilver 35-883702K), than the one installed before, (Quicksilver 35-883702Q), they said it was a superseded part. Installed new filter and used the recommended Merc 25W-40 synthetic blend oil.
Now, the audible alarm is beeping 2 short times anytime the power is reduced from plane to idle. Oil is 45 PSI (@ 1500RPM aprox), I say aprox since my RPM gauge is now inoperative, I dont know why but dont think is something related. The temp is peg @ 180. All fluids are topped off. Could it be a bad sensor? If so, how can I test it? Are the oil pressure and water temp within range? Will the new, longer oil filter be the issue?
Thank you very much.
