Re: merc 350 heads
Hey guys,
Since no one bit on the first thread, I'll revise it. I removed the factory head(the bad one,no gasket mating surface left between the water jacket and cylinder, salt just ate it away) has a casting # 14096217, I checked into it and it's supposed to be a crate engine, 55-86, 350cid, 285/300hp, 64cc chambers with either 72 or 90 degree center intake manifold angles. The other head, which is a replacement, has the casting # 14102191 and all I could find out about that one was it was a 350 manufactured from 1987 on. Before I took the bad head off, I did a compression test and the compression is running around 160 PSI on all the good cylinders. Can anyone tell me were they get 260hp from for this motor?
thanks
jeff
