1979 Mercruiser 260... in a 23' Carver.
When changing spark plugs, coolant escaped from behind the #5 plug. I changed the oil and found coolant in there, too.
I have pressure tested the cooling system and it's leaking, but I can't tell from where... Any tips on how to determine of the head is cracked or if I am "lucky" and just have a bad gasket...
PS, the motor has been run quite a bit this way - maybe 30 hours or so. I have owned the boat for 3 years, ran numerous fishin trips the first year, then only a few last year (spent 4 months trying to remove a starter without pulling motor and outdrive - fun!). The motor has run smooth the whole time, without any stutter or mis that I could detect. It steams a little when on the muffs, but I assumed that was normal...
