Merc 228 mechanical fuel pump issue
Raystownboater
attachment.php
Im trying to replace the fuel pump on my mercruiser. I purchased a mechanical fuel pump for a small block chevy and as you can see, the mounting surface does not match. What am I doing wrong and what fuel pump will fit this block? I've checked every small block mechanical fuel pump and they are all the same.
The block was ordered from Rapido with a plate on the block because at the time, I had an electrical fuel pump. So, I dont have the old pump to match up.
Raystownboater
Re: Merc 228 mechanical fuel pump issue
WOW, not sure why that pic is so big..............but I think I may have answered my own question. I was looking through the service manual and it looks like there is a plate between the block and fuel pump that I am missing. Now to try and locate that plate!
RogersJetboat454
Do you need one of these?;
http://www.summitracing.com/parts/NAL-3719599/
Pump won't work without an adapter plate...;)
Don S
You also need the fuel pump pushrod.
attachment.php
Raystownboater
Thanks for the heads up, Don. I ordered the plate but didnt realize I needed the pushrod. Just called and added the pushrod to the order. Thank you!
RogersJetboat454
Good point, without one you may be disappointed with how well your new fuel pump works...
Make sure you put some assembly lube on the pushrod shaft and it's tips. A nice thick assembly lube will help hold the push rod in place while you install the pump.
No matter what, I would refrain from using plumbers putty to hold the push rod in place. :D
http://forums.iboats.com/showthread.php?t=480371&highlight=Plumbers
Raystownboater
Plumbers putty never would have crossed my mind! Good to know, though.
mkast
Does the pushrod go into the upper or lower hole in the block?
I image it will go in the hole it fits in.
Use vaseline , DO NOT USE PLUMBER"S PUTTY.
Raystownboater
There are two holes in the block. If you look at Don's diagram, the pushrod is positioned at an upward angle like it would be installed in the upper hole. Just dont want to bend or damage anything by installing the pushrod wrong. I didnt even think about vaseline, though, Thanks!!!
mkast
When you see the push-rod, this will be a non-question, it will only fit one of the holes.
Raystownboater
Yeah, common sense is lacking, on my part, this morning. Probably should have waited til the part got here to look at it. Thanks for the info.
daydreamer1252
Whoa....must be cold where you are working....if I were to use vaseline here it would melt and rundown before I could pick the fuel pump and gasket off the deck to install it....wish I were where you are....:)
Raystownboater
If I refrigerate the vaseline prior to using it and install the pump in the middle of the night, I should be able to get it in before it melts!
four winns 214
I changed the mechanical fuel pump last fall on a Merc 228R with a Rochester Quadrajet carb. Upon starting the engine, fuel leaked profusely from the carb. Long story short, the solution (obtained by calling Merc) was to use the much thicker gasket intended for 3.0L applications. Here's a link to the thread about it:
http://forums.iboats.com/showthread.php?t=437166
Raystownboater
Thanks for the info Four Winns. Is this a common enough occurance that I should just go with the thicker gasket right away?
RogersJetboat454
I wouldn't. See what the fuel pump you get does with the correct stock gasket. That thicker gasket deal sounds like a band-aid to fix another problem. There are hundreds of thousands of boats out there using fuel pumps with the correct thickness gasket....
mkast
Must be warm there today.
Petroleum jelly is a semi-solid mixture of hydrocarbons, having a melting-point usually within a few degrees of 75 ?C (167 ?F).
http://en.wikipedia.org/wiki/Petroleum_jelly
