jscgdunn@telus.net
- Aug 8, 2007
- 9
I have a 200 Merc V6 and the Oil alert warning is on all the time while engine is running. That is, until I disconencted the green wire from the switch box.
I checked and the pump is pumping oil fine and level in engine tank good.
I also own a manual! The first troubleshooting possible cause is a "defective ignition system (incorrect voltage being sent to warning module.) The "Corrective Action" states to "check for the correct voltage with a DVA."
Might be a dumb question...but what is the correct voltage? I checked all three on the outside switch box and they ranged from less than one volt to 5-6 volts. Boat runs fine.
