Merc 200 EFI
swr-pmr
I have a 1998 200EFI Merc. that has low hours and has been in storage for a year. Absolutely no problems before that, but now it won't start. Plugs have fire, and are nearly dry, even after extensive cranking. <br /><br />Is there a trick to get the fuel injection working again? <br /><br />Any comments appreciated.
clanton
Re: Merc 200 EFI
Is fuel pump working, and did you check fuel filters, after this check fuel presssure.
my new fishmaster
Re: Merc 200 EFI
Sounds like the kill switch which is designed to kill the motor if you fall out of the boat. Its in the off position
swr-pmr
Re: Merc 200 EFI
Thanks for the comments. As it turns out, "Stabil" in the gas tank does not equal stabil in the engine, unless you run the engine for a while. Has bad gas at the fuel injection/oil mixing device, and eventually got fuel to this device by pressing the schrader valve on the fuel system, while pumping the fuel line bulb. After starting,had a steady pulse of fuel from a vent on what I believe is a return line to the fuel injection system----took it to the shop--and mechanic confirmed the injection mechanism has a needle/seat that is problably stuck and return fuel could not return. Basis disassembly and cleaning of injector device required.
clanton
Re: Merc 200 EFI
The device is a vapor separator, and has a float and needle, just like a carbuator.
