merc 200 chrome bore
kenthrussell
hi again could this be aluminum transfer deposits from the piston?the bore is not scored bad at all it almost feels a little bumpy when running your fingers down the sides of the cylinder wall, tried some muriatic acid to the bore but it will take a while, the history on this engine is that the oil pump failed but the motor was shut down before seizing,other then just the one bore all the rest look good,how thick is the chrome plating?
