I have about finished moving the Merc 200 off of a boat I purchased and installed it on my boat. I took it out and had very low amounts of water out of the pee hole. Also, I ran it for a while and temp gauge got close to 200 degrees. <br /><br />I had the dealer put in a new impeller. The old one looked OK. <br /><br />I ran it yesterday and pee hole is stronger, but not as strong as I thought it should be. Temp gauge was around 185 degrees when running. The sender is mounted on the starboard head.<br /><br />Is this normal?? I ran the same temp gauge on a Johnson 150 and it would idle at 140 degrees and run at 125 degrees. <br /><br />Does anyone know what the thermostats are normally set at??<br /><br />Thanks for any help!! I don't want to lose this motor!! Also, I did not get any alarms.
