Re: MERC 170 STATOR?? HELP
stevie, the stator is located under what would normally be the harmonic balancer on the front of the crankshaft. as far as losing charge in the battery,put a amp meter in line with one of the battery cables and check for a draw on the battery. if there is a draw , remove the fuses for all the circuits on the dash one by one,checking the meter after each fuse you remove. if the draw is still there then remove the orange wire from either the starter or voltage regulater which ever is easiest, this disconnects power from the voltage reg.located port side under exhaust manifold.if the amp meter drops, the draw is at the reg. these regulaters are water cooled ,so if this engine has over heated at one point in time it could have caused damage to the reg.a bad stator usually won'tput a draw on a battery
