Merc 150pro xs to a 200 hp.
Baldy177
Is it possible to convert a Merc 150 to a 200? What would I have to change? Throttle body and PCM ? Thank you for your time.
jimmbo
Get the Parts Lists for both engines and go thru them, noting which parts are Different.
If they have the Same Displacement, then it Might only be some of the Following, the Block, Heads, Pistons, Intake and Reeds, Throttle Body, Exhaust Tuner, PCM, and a few other Parts.
