Re: Merc 1500 won't rev
Motor is a blue stripe, will post serial number here shortly. Ran great in the morning, I did a sea foam treatment through tanks and also sprayed into carbs. When I got to the lake it had a hell of a time starting, and would only idle around 1500rpm and stumble.
Wondering if anyone can help me track down the problem. Simple voltage checks first? I currently only have a clymer manual to work with. Seems like I might have a varnished carb
