I have a 2000 Merc 150 saltwater series (2 stroke) that has been losing power when I run it above 4200 rpm's or so. It started a month or so ago but wasn't consistent till now. Details and checks to date:
suspected fuel from the beginning, so I have sta-bil in the tank, about 35 gallons in there now (premium fuel)
plugs are new and old ones were clean
visible fuel lines appear solid
new h2o separator
new fuel filter
when getting on a plane it takes off strong, then at 4000 or so it will surge and lose rpms, bulb is still firm..
so, I wanted to test the carbs one by one by taking off air box and I was going to choke one by one to isolate, but when I took off the airbox this time, I noticed oil traces on top of air box and slight oil in carbs. could have dripped in when I took off air box. ran the boat with airbox on to see where oil is coming from and it is coming from the resevoir cap? seems to be on very tight..
all other gauges read fine, temp, etc...
It will hit WOT once in a while. I thought it could be a cylinder but wouldn't that have gone out and been done, not work on occasion?
Trying to think if there is anything else.. Fuel pump has not been changed..
Am I missing something? Doesn't feel like a power pack problem, but what do I know?
Thank you for your ideas.
Senator20
new h2o separator
new fuel filter
Senator20
