oba97
- Jul 28, 2015
- 277
I have a 2017 Mercury 150L EFI that will bog down intermittently at WOT. I can idle and cruise at 3/4 throttle no problem, but when I go full throttle it will get up to speed then bog down a bit then go back up to speed. This will continue until I back off a bit. I changed the fuel filter but this still happens.
A little more info…..
When this first happened I had a boat with 4 kids on it so I didn’t want to dig into it too much at that time. A couple days later I went to go out and the boat wouldn't start. I trimmed down the motor but after that nothing worked. I pulled the battery and brought it home to charge (I keep my boat in a marina). As it turns out the battery was fine. So…I went back and cleaned the wire terminals as best I could because the had a decent amount of corrosion and then tried to start it. It started right up. But I have been out three times since and it continues to happen at WOT. I also don’t think I’m getting top speed anymore.
My gut says this is fuel related but could corrosion on the terminals cause this issue? I have read a thread about adjusting the shift cable so I might give that a shot.
Any help is greatly appreciated.
