merc 140
Dennis Evans
merc 140 runing 180 DEG under load it has a new <br />seawater pump and a new thermostat. Could the parts from the old pump be someplace they should not be?<br /><br />thanks
Laddies
Banned
Re: merc 140
Did you ck the water intake, underneath the pump peices will fall down the intake when the impeller loses fins, just pull the covers off the intake and take a look--Bob
tommays
Re: merc 140
if the pump was missing vanes they are in there somewere<br /><br />did it run at the correct temp in the past<br /><br />you dont say how old it is but at some point the exaust manifold and elbow will clog and block water flow OUT of the motor<br /><br />tommays
