Overheated on the lake on Saturday and suspected the impeller and or thermostat. Pulled the lower for the first time and here is what i found
. The pump housing appears melted and the impeller looks too big. Should the impeller diameter be 1/4in+ bigger than the diameter of the housing? Also it appears the "impeller key" may have slipped out and let the impeller not turn with the shaft. I dont even know if this is possible, is it? Hose from outdrive to thermostat housing was to hot to touch and temp gauge read 250F. What else could I have damaged? See other post with thermostat photos. Its FUBAR also... Thanks for any reply...
