Merc 135V6 - Troubled starting after long warm-up
After running my motor for a while I turn it off to go fishing. When I try to turn it back over, it does not start right away. I have to put the throttle into neutral-forward and cranck it that way or it will not stay on in idle. <br /> This is particularly difficult if I'm fishing a rocky shoreline because I need to get it started in a hurry if I'm drifting too close to a rock pile.<br />Is there something simple I can try to fix this?
Terry H
Re: Merc 135V6 - Troubled starting after long warm-up
Doug...I'm certainly not an expert with Mercs, but it almost certainly has to be a fuel problem...if you get a lot of smoke when it finally does start you might have fuel leaking out of carb causing flooding...first things I do when I do not have a obvious solution to a problem is a compression check, spark check, fuel supply check (all the way from carb to tank vent). <br />If you don't see much smoke when it finally starts<br />you may need to simply use the choke, or enricher to get it restarted. Keep trying someone has the answer...just a Thought
sag2
My dealer sold me some little restrictors to put in the drain tubes that run from the side if the block.I believe there was a bulletin on it. It helped mine to start easier after a hot soak restart. If you need a picture of where they go, send me a note at stangozzi@aol.com
