Where can I find the fuel lines the run to the carbs, the have threaded ends on them? They appear to be discontinued. Is there a way to get around this?
Last Year I posted the parts numbers on the brass fuel fittings you will need. The compression fittings on all my vintage silver blocks had to be replaced with barb/nipple combinations and then ya jus use 5/16 alcohol resistent gas line from yer local NAPA or outboard shop. I don't have the parts or numbers handy here in town, and it maybe weeks before I could put me hands on em. Try a serch here on posts last summer/spring on fuel fittings for a 1250 or 1000, (the 1000 silver blocks had the same loop set up from the two fuel pumps to the three carbs).
