Can somebody please help me with my engine problem?<br /><br />Motor is a 1969 Mercury 1250 with thunderbolt ignition. It runs fine for about 15mins, then it will stall when I put it into gear and open the throttle.<br /><br />What I have done so far is:<br />- Had carbs stripped, cleaned and synchronised<br />- replaced plugs and leads<br />- replaced distributor, reset timing<br />- replaced fuel tank and lines<br />- replaced forward control and wiring harness<br /><br />I had somebody tell me it moght be the coil getting hot, and failing, but I don't know how to test for this.<br /><br />Also, the tacho no longer works - but that might be a separate issue.<br /><br />Can anybody help?<br /><br />thanks
