Merc 120 wont turn over.
Ian5972
Hi. I have a Merc 120. New starter and battery. The engine will not turn over. I put a crow bar onto the flywheel and it will not turn. Can a frozen or seized universal joint cause this. The engine has not turned over for a year. I assume I will have to remove the outdrive to prove whither its the engine or the outdrive. If it was stuck in gear could this sympton occur.
Help please.
Regards
Ian
Re: Merc 120 wont turn over.
Ayuh,... Anything is Possible,... But,.. You won't know til you pull the drive...
Brian Drew
Are you sure your wiring is right,And I would check the starter slave soleniod first off.then poll the top drive.
Bt Doctur
Pull the drive to isolate it.
Was it winterized?
Is this your boat or a recent purchase?
Did it ever run?
Ayuh,... He's just alittle past the electrical problems Brian...
Brian Drew
did you leave your plugs out at all,and I think you need to pull your out drive and find a buddy with a special shaft to unsease this issue.
Ian5972
Was it winterized?
Did it ever run?
Yes it did run last year, and yes it was winterized. Can a frozen U Joint cause this?
Ian5972
Ive pulled the plugs and sprayed in some WD40 releasing agent. I also filled the Stern drive reservoir with wd40 as I discovered it was dry i.e no oil, Gears and pinions appear to be ok. I have left the WD40 in for a couple of days. I think your right about pulling the outdrive. Only way to isolate the problem
Ayuh,.... Pull The Drive....
You're 6 or 8 nuts,+ a 7 dollar gasket set away from the Answer to your Questions....
Ian5972
Drive pulled and u joint roller bearing seized in housing. Have left overnight in wd40, will attempt to unscrew retainer tomorrow. Engine turns over ok. It looks like u joint bellows have a hole and water ingress has caused this problem.
Thanks guys for all you help, great forum
Regards
Ian
