Bigjohn1
- Jul 19, 2005
- 170
Engine: 2004 Merc 115efi. <br />Problem: Suspect regulator is allowing alternator to over-charge battery.<br /><br />300 hours of flawless running. Only problem has been regulator is allowing between 15.3-15.8 of charging voltage. While this is within factory specs, it is causing me have to add about a pint of water per month to my current wet cell battery. I should not be using this much water in a battery and am about to replace the battery to an AGM. Since you can't add water to a sealed AGM, I am worried this charging rate will simply ruin a $200 battery over time. I have tried<br />"adding load" while running by switching on some additional electrical components but it has had almost no effect on amount of water being boiled out of the battery. Any ideas on what I can do? From what I understand, the voltage regulator is pre-set and non-adjustable.
