My merc 115 will only turn over ever so briefly when turning the ignition key.  The starter almost immediately jumps out, though not always.  This is particularly noticeable when while still in neutral I have the throttle forward as is the normal starting drill for this motor.  I had it running fine before I removed the lower gear unit to change the water pump.  I have plenty of battery and it seems that it would start fine if I could just get it to turn over long enough.  Any ideas?  I'm going nuts.  I pulled the plugs and they are pristine.
