Merc 115 2+2 RPM Gauge
Superjetjim
Hi,
My RPM counter doesn’t work on a boat I recently purchased with a Merc 115 - can I simply check for voltage on a wire on the back of the gauge perhaps, or is it more complex than that?
Also - is my engine a 93 looking at the serial number 09776985?
Thanks for any help!
Jim
GA_Boater
Is the battery charging? If not a duff rectifier/regulator or stator can cause a non-working tach.
Superjetjim
OK Thanks GA, so am I looking for around 14v at the battery when running (rather than say 12v when off)?
Its a new boat to me (not been in the water yet so not sure if charging yet, but can test on the hose / test tank.
Superjetjim
So thanks for the advice above - I had the boat out today for a good run. The RPM gauge ‘twitches’ when you switch the ignition on, but doesn’t display any RPM or move again after that.
Battery voltage readings are:
Motor off (after a good run) 13.4v
Motor running at idle 14.14v
What’s the likely culprit then, regulator/rectified or RPM gauge??
First run out in her today, they idle so smoothly these 2+2’s, I was actually quite impressed. Bags of power out the hole as well.
Thanks,
Jim
jimmbo
I think it is either the gauge, or a bad wire/connection to it
However, what voltage reading are you getting at WOT?
Superjetjim
How would I test if it’s the wire from the motor to the gauge? Is it just a case of running another grey wire from the motor to the back of the tach?
GA_Boater
Blue, purple, fucshia, puce - Any wire color will work to test the tach. Just hook it up to the motor and run it to the tach as a temporary test.
