gatesmoonwalker
- Sep 18, 2008
- 20
Mercruiser 5.7 - MerCarb 2 barrel
Working a hard start when warm problem. Looks like sticky float.
Question is this. Started diagnosis with choke first.
Engine cold and noticed the choke plates wide open.
Further investigation I see that the pressure of the idle speed screw
on the idle cam is holding the choke open. Slight movement on the throttle
is all it takes to release it to the closed position cold.
I have never had a problem starting this boat cold and only this year ran into the warm start issue. I typically use the starting procedure outlined in the sticky section so I assume my throttle pumps have released the plates.
This normal or what is my fix?
