I have a '95 115 Mercury.
I was on a two mile run back to the dock and was headlong into white caps the entire way so it was a bumpy trip. As I approached the cove, the temp alarm went off intermittently. I was peeing water with a strong output. I loaded up and was at camp in less than 5 minutes. After about 10 minutes I smelled an intensely putrid burning odor. I then see the white smoke rolling out of the engine.
I took the cover off and the stator was bubbling, the regulator burned a hole through its bottom.
So I've received the new regulator and put it on. I'm waiting on the stator. In the meantime, I "cleaned up" the stator, cutting away all of the melted material and sanding back to original size. I had resistance out of the stator within specs. I put it all back together and thought I could just bypass the stator and pray for a start. But I get no spark. I've tried it completely disconnected. I've tried it with both yellows disconnected and the blue/white and white/blue connected.
I've got 12.5 V at the battery and 11-12 V during crank.
This engine also has an adapter in-line out of the stator.
Is there more troubleshooting I can do to find faulty components while waiting for the stator? Of course we'd like to enjoy the lake on the 4th but by the time the stator arrives, there won't be much time to get additional parts.
If I smoked the stator and regulator to that point, are there some high percentage components that would also be damaged?
