alphadog808
- Nov 28, 2009
- 33
Hi guys,
I have my 2015 Honda BF50(~250 hours) at the mechanics and they have had it for about a week and they can't figure out my stall problem...hoping you could maybe assist.
Background..was fishing the other week and after idling for an hour or two, when I'd go into gear to move, the engine would die about 20 seconds in. I would restart the engine and it was fine. I moved to the next spot, and when I went to move again(1-2 hours), it died. No biggie, right? Of course, when we decided to go home, the engine died like before. I restarted the engine assuming we'd be fine...but no, it died again. It did it about 3 times. Finally, I ran the boat at a lower RPM, and started chugging home. About 20 minutes in, I decided to chance it and I revved up the engine and to my surprise, it didn't die and we raced in(~15 miles). No problem.
Note, I changed fuel tanks and I had the same prob with both tanks.
Went to the harbor the day after, took off the prop and ran the engine in a bucket. Idled for 30 min and put into gear. No problem. Idled for another hour and it died when I put it in gear. However, at this point, I couldn't even start the engine. I took the boat home and 3 hours later I fired it up and it started on the first crank.
Took it to the mechanic and they did the usual checks and diags and they said everything was ok, no hose leaks, gas was good, no errors, cooling system looked ok, compression good, checked the VST, etc. Had them try to idle for a long time and then put into gear...they couldn't reproduce it.
Also wanted to note, the engine had been stumbling at 4k RPM a while back but the mechanic had changed out the high pressure fuel pump as he said it was out of spec. Otherwise he didn't find anything amiss. I think it ran fine after that change.
Last I heard they were thinking/hoping the grommet on the high pressure fuel pump might be blocking the fuel so they are going to check that...other than that, any thoughts?? Only other thing I can think of is I recently changed my racor fuel filter(S3240), but the mechs didn't see any residue/blockage in the vst and it ran fine when I booked it home the day I had this issue.
Thanks in advance!
Thanks in advance!
