Aquadzac Captain
- Jun 26, 2004
- 112
350 OMC Cobra Outdrive Eldebrock 600 cfm, 2.45 footer:<br /><br />PROBLEM: Ran 30 minutes great, went down to idle stalls. Cooled off Ran great 30 minutes, wont idle stalls! Over and Over<br /><br />SOLUTION FOUND: Added Gauge to Fuel line. Fuel line pressure started at 5.1 psi and gradually fell to 1.5 psi in 30 minutes. Causing stall situation on low idle. Mechanical Fuel Pump seals went bad on heat up. Replacing to Elec Pump.<br /><br />Just passing on...
