ok, I did the thing in my west marine catalog and measured from the middle of transom to back corner, then back corner to steering wheel, then from outside to center of steering wheel...came up with 14'
factory system is a rack/pinion type.
I then finally managed to beat/cut the old steering shaft out of the engine bracket and then cut out the black portion of the cable. measuring just the black portion from end to end (where it connects to metal on each end) it measures 11'-3"
If I then add in the 1' or so of the metal transom end it comes out to around 12'-7"
question
so am I correct in that I need a 12' cable versus what the book measurements are telling me @ 14'??
question
