Last year when doing work on my lower unit I noticed water had been getting in and around the driveshaft. Thinking it was just the bellows I replaced them all, but never did find a tear in the driveshaft bellow. I used the boat a few more times before putting it away for the season. This year I kept tripping the shift interrupt prematurely and it appears the shift cable has a lot of resistance. I've decided to replace it and removed the lower unit to find water inside the driveshaft area again. The bellows looks good, the outdrive gasket didn't look compromised, any chance it could be leaking around the shift linkage? Is there a seal kit I should be looking for?
