ziggy
- Jun 30, 2004
- 7,473
started working on impeller replacement the other day. drive is in the basement.
drained gear lub. no metal feel to lub it at all. pretty much the same color it went in (maybe a shade darker). green (mercruiser hp gear lub). no water intrusion. no issues last season. gear lub did get changed mid summer last season just as pm. pressure tested prior to disassembly. no loss of pressure.
with the drive, upper and lower together. when i rotate the drive shaft. i feel like i'm feeling gear teeth. with upper and lower separated. when i rotate the drive shaft on the upper. i still feel like i'm feeling gear teeth. or maybe brgs.?
is this normal? do i have any reason for concern? i don't remember it being that way.
used it a 100 hrs + or - last season, that's a guess...
driven gear yoke and ft. seal and brgs replaced, 2 seasons ago by me. did reshim. couple hundred hrs on it since i did that to it..
