ziggy
- Jun 30, 2004
- 7,473
so i've been doing a little prep on my drive.
R&Red the impeller
R&Red top brg and race in upper driven gear shaft
things looked respectable so i put her back together again. pressure tested at 14 psi for 24 hrs. rotated drive shaft, prop shaft engaged in fwd. no loss of pressure.
did a vac. test. initially it held at 5hg. but tended to drop off. down to 4 or 3hg. rotated drive shaft, prop shaft engaged. fell off to 2-3 hg. wouldn't hold for 15 min. started seeing a drop pretty much right away.
so i separate the upper and lower again. vac. tested the upper by itself. 1.5 hrs later it was still steady at 5gh. right where i put it. did rotate shaft. so i think to my self, must not be the upper.
vac. test the lower. well, it's now been holding for 2.5 hrs at 5hg.. rotated shaft, tried to wobble drive shaft. still holding.
yes, the quad ring was in place.
upper
very bottom seal (the easy one) of upper was replaced 2 years ago, looks serviceable
oring replaced on top cover
perfect seal on retainer nut
lower
no service at all to the lower other than the impeller. to include not doing the water pump base seal...
any one got any ideas as to why it failed a vac. test when assembled? i figured when i tested the upper and lower separately that it'd lead me to the leak..
have not tried pressure testing separately..
R&Red the impeller
upper
lower
