afirststep
- Sep 24, 2011
- 11
I just bought a 1999 Maxum 2400 SCR with a 5.0L Mercruiser. (Wife loves loves the upgrade from a W/A and head!)
With two people the boat runs WOT at 4100RPM at 36MPH with a 14.5X17P 3-blade Michigan AL prop. (prop rebuilt recently.)
With 6 people and 35 gal fuel, the boat will not make it past about 3400RPM and not get up on plane. (Yes I tried to use the trim tabs and engine trim to get on plane. Also shifted people forward...)
NOTE: trim tabs work, Compression 190-195psi all cylinders, rebuilt 2bbl carb, fresh fuel (Blue enzyme and ethanol Stabil added), fuel pump pressure check OK, new fuel filter/separator, boat hull is clean (Trailered).
I was debating with my boat buddy if a SS 14.5X15P or 14.5X17P would be better. Since the top end should be 4400-4800PRM, I have 300 RPM to give to the 15P prop. It would improve the hole shot and allow the boat to get on plane easier and with a bigger load. He says that a 17P SS will not flex and would solve the high load hole shot problem and retain maximum cruise efficiency. We were also debating putting a fuel injection add-on to boost the HP from 230 to 10-20HP more....
Help! Is it possible to rent props to try both pitches (15P and 17P) out before purchasing? Can anyone make an educated guess which way to go? (Are we both wrong?)
Thanks!
Thanks!
