Re: Maxum 1800sr inboard blowers not working
Does anything else electrical work, or is it just the blower? If nothing electrical works, check to see if the battery master switch is closed (on). Its located next to the battery. <br /><br />I have a 19' Maxum, the fuse panel is ahead of the helm, accessable by lifting up the starboard seat back cushion just ahead of the windshield. Check the blower fuse. The blower switch is accessable thru this opening also. If not the bat switch or blower fuse or blower switch, time to check the wiring from the switch to the blower. Turn off the bat switch (to eliminate sparks!) and pull the connector off the blower. Check continuity across these two terminals with an ohmmeter. With the blower switch off, no continuity, switch on, zero ohms (or close to zero). If switch checks out ok, buy new blower.
